![]() | Home > General > Fuel Burning Heater not working. |
joboco Member Since: 13 Sep 2021 Location: Scotland Posts: 24 ![]() ![]() ![]() |
Update. I now have the manual controls illuminated but still nothing working. If I had any hair I would pull it out in frustration. |
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 ![]() ![]() ![]() |
I think for the parking heater to kick in, the battery has to be above a certain voltage and there has to be at least a quarter of a tank of fuel, so if the battery or fuel are low it will not fire up, also I think if the heater fails to fire a certain number of times it goes into a lock out mode which can be reset with the GAP tool, does the heater fire up when you start the vehicle at low temps of 6 Deg and below ?, There's a full section on the fuel burning heater on the disco 3 forum. |
Thanks for the reply. I have a full tank of fuel ambient temp -2. It doesn't work on timer or manual heat. It doesn't work with or without the engine running or whatever the temperature is. |
Yet another update: the heater is now working. After advise from a first class indi (Strathearn Engineering Perth) I found more settings on my Gap lld for the heater and cleared all codes. All is now well. |
