Home > Technical > Retro fit an electric steering column
Simon_CSK
I have bought and am rebuilding a 2007 Sport with an electrical fire.
The fire damaged mainly the wiring loom over the bulkhead with some residual damage to air intake, left rocker cover and various electrical connectors.
Having a donor vehicle I am in the process of the rebuild and in stripping the dash yesterday I, with great relief, discovered it had the manual steering column. I say relief as I needed to drop the column to remove the speedo head.The donor vehicle has the electrical one and I will be changing all the ECU's and BCU etc from the donor as I know they all work but cannot vouch for the project.
Is it a straight forward fit? The donor is a 2008 model. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #619400 Mon Nov 22 2021 8:48am
Will it mechanically fit you mean?
I guess you will find out !
Post #619414 Mon Nov 22 2021 6:09pm
Simon_CSK
Mechanically it will have no doubt am more concerned with the electronics. Will know more when the dash is out as to what terminals are present. Current cars
Range Rover CSK
Discovery 3 HSE
Post #619415 Mon Nov 22 2021 7:01pm
