Home > Faults & Fixes > Reduced Performance |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Error codes are incomplete so assume it's a generic code reader. Could the be a split inlet manifold - not unusual. 2012 SDV6 - it's missing a couple of cylinders
Fri Nov 05 2021 11:11pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 202 |
Mine was a crossover pipe same model year at the rear close to the bulkhead. It took a few trips to the shop to get it nailed and was a quick fix. 2018 Telsa MS
Sat Nov 06 2021 6:04pm |
MarkSTurner Member Since: 25 Jul 2021 Location: South Wales Posts: 4 |
Thanks for replies / thoughts guys; having erased fault codes with diagnostic tool car is now seemingly back to full performance …… watch this space 🙄😁😁👍 |
Sat Nov 06 2021 9:08pm |
MarcMGD Member Since: 30 Nov 2020 Location: Essex Posts: 22 |
Hi I posted about a similar issue the other day but didn't get any responses on here.
Sat Nov 06 2021 9:21pm |
Your error code is incomplete but is possibly down to a cracked inlet manifold. It's a known issue, sadly. Solution is to fit a new one. Not the cheapest of jobs, sadly. 2012 SDV6 - it's missing a couple of cylinders
Sat Nov 06 2021 11:04pm |
It took my Indie a few tries to find the crossover pipe issue, the car would behave for days then the fault would appear. A few codes appeared but nothing leading to the crossover pipe. This was on a MY12 3.0. 2018 Telsa MS
Sun Nov 07 2021 10:24am |
I dont get any error codes other than the P1247, I've tried several diagnostics machines including a land rover one and can't get anything more coded. The p1247 happened once and only once. Is it common for the boost noise leak noise to stop around 2500rpm as the second turbo kicks in?
Sun Nov 07 2021 12:30pm |
Mine sounded like the turbo had been bypassed when it occurred. Again codes didn’t help, time to find a good indie to help out. 2018 Telsa MS
Sun Nov 07 2021 1:38pm |
