Home > Faults & Fixes > Reduced Performance
MarkSTurner
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Reduced Performance
Hi my RRS 2012 HSE went into limp mode two days ago shortly after start up on a cold frosty morning, however after having switched off and restarted all seemed to be good again warning light gone and full performance restored. Unfortunately warning light and reduced performance returned today while driving on motorway. Diagnostic revealed fault codes p2263 and p007A, so I erased codes and have driven all day with no issues. Engine pulls like a train, no smoke etc beautifully smooth. Any thoughts what problem could be ? Thanks
Post #618777 Fri Nov 05 2021 7:30pm
Error codes are incomplete so assume it's a generic code reader. Could the be a split inlet manifold - not unusual. 2012 SDV6 - it's missing a couple of cylinders
Post #618788 Fri Nov 05 2021 11:11pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Mine was a crossover pipe same model year at the rear close to the bulkhead. It took a few trips to the shop to get it nailed and was a quick fix. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #618814 Sat Nov 06 2021 6:04pm
MarkSTurner
Thanks for replies / thoughts guys; having erased fault codes with diagnostic tool car is now seemingly back to full performance …… watch this space 🙄😁😁👍
Post #618817 Sat Nov 06 2021 9:08pm
MarcMGD
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Hi I posted about a similar issue the other day but didn't get any responses on here.
Mine is doing the below
Looking for abit of advice, I put my footdown the other day and experienced a restricted performance scenario. My friend came straight to me plugged in the snap on diagnostics and it only produced a p1247 code.
Anyway turned the car back on and problem gone. Hasn't happened since and have had the machine left with me for 2 weeks so I could check and not a single issue of restricted or accompanying error code. However I do get a boost noise up until I believe turbo B kicks in circa 2500rpm and then the boost leak noise stops.
Can someone point me in the right direction as I can't find any faults matching mine?
How did you ascertain it was a crossover pipe?
Post #618818 Sat Nov 06 2021 9:21pm
Your error code is incomplete but is possibly down to a cracked inlet manifold. It's a known issue, sadly. Solution is to fit a new one. Not the cheapest of jobs, sadly. 2012 SDV6 - it's missing a couple of cylinders
Post #618820 Sat Nov 06 2021 11:04pm
Puslinch
It took my Indie a few tries to find the crossover pipe issue, the car would behave for days then the fault would appear. A few codes appeared but nothing leading to the crossover pipe. This was on a MY12 3.0. 2018 Telsa MS
1990 Porsche 944
Post #618826 Sun Nov 07 2021 10:24am
MarcMGD
I dont get any error codes other than the P1247, I've tried several diagnostics machines including a land rover one and can't get anything more coded. The p1247 happened once and only once. Is it common for the boost noise leak noise to stop around 2500rpm as the second turbo kicks in?
Thanks
Post #618829 Sun Nov 07 2021 12:30pm
Puslinch
Mine sounded like the turbo had been bypassed when it occurred. Again codes didn’t help, time to find a good indie to help out. 2018 Telsa MS
1990 Porsche 944
Post #618830 Sun Nov 07 2021 1:38pm
