![]() | Home > General > RRS 2010-11 New Recall from JLR |
Checked mine and yep:
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 247 ![]() ![]() ![]() |
Just checked mine is on the list, Anyone contacted them for an explanation what’s exactly involved in this recall and if its worth doing? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4449 ![]() ![]() ![]() |
Essentially, gluing the outer cover to the inner frame |
That’s interesting as i glued the spoiler on one corner last year noticed it was loose, Probably not covered now if they see someones glued the corner themselves, wonder if my indy can check and so the work if needed on next service? |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 189 ![]() ![]() ![]() |
My Rear spoiler became a sail that would power an America's cup boat..... |
Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 79 ![]() ![]() ![]() |
It came up for me, but the spoiler was replaced before I got it last month. So I’m not going to rush in to get it done. 2010 HSE TdV8 in Stornoway Grey.
Flyfisherman Member Since: 12 Sep 2020 Location: Staffordshire Posts: 91 ![]() ![]() ![]() |
Mine flew off a couple of months ago and got ran over by a tractor. Got one from a breakers yard and had it spayed. Total cost was £450.
woodsie Member Since: 23 Nov 2015 Location: Milton Keynes Posts: 67 ![]() ![]() ![]() |
Just checked mine on the dvla site and no recall logged.
Maybe they rattle loose on the clattery diesels but not the smooth petrols |
So does anyone know what the actual fix is? A nice new fancy spoiler for free or do they stick some glue on and send you on your way with an unwanted quote for £5k of other work not needed? |
If only ![]() ![]() Mine is a 5l SC and still took flight ![]() |
My Thoughts too. I need a full unit with camera - seriously doubt JLR will cover it!! ![]() |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Did wonder if this was just the HSE spoiler or if it included the A/B's, which would easily confuse a L/R dealers if the recalled one's were HSE's which had a A/B kit fitted later in life, and not factory produced A/B's. |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
Thanks to the OP for the heads up.
