Home > General > High beam bulb |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
yeah, main beam is H7.
Sun Oct 17 2021 7:58pm |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
I am aware you can get HID in different colours, but is it as simple as just changing the bulb? Or does the ballast need to be changed too? |
Mon Oct 18 2021 8:21am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
The H7 is described by LR as a fill-in light to ensure good pattern spread. The main beam proper is provided by the xenon unit.
Mon Oct 18 2021 8:22am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
If you have =Xenons then the high beam is a fill in globe with the hi beam being provided by the HIDs in the outer lights.
Mon Oct 18 2021 10:45am |
As said the H7 main beam (on xenon models) is to.
Mon Oct 18 2021 12:13pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
I run aftermarket H7 LED bulbs (6k) and together with the Xenons provide a fantastic output. Do a search on here for a thread on LED bulbs.
Mon Oct 18 2021 6:39pm |
