Home > Technical > DTC U0434
Supercoops
DTC U0434
Hi all just had my codes read after throwing the Red warning suspension fault light. My 2008 has a slight weep of fluid from the ACE filter block plug. Filter not long been replaced and new plug/o ring fitted. Level is fine in reservoir. Would this weep be enough to throw the code or should i be looking elsewhere ? wiring DRM level sensors etc
Thanks in advance Pete
Post #617292 Tue Sep 14 2021 7:13pm
