![]() | Home > Technical > DTC U0434 |
Supercoops Member Since: 14 Sep 2021 Location: North East UK Posts: 2 ![]() ![]() ![]() |
Hi all just had my codes read after throwing the Red warning suspension fault light. My 2008 has a slight weep of fluid from the ACE filter block plug. Filter not long been replaced and new plug/o ring fitted. Level is fine in reservoir. Would this weep be enough to throw the code or should i be looking elsewhere ? wiring DRM level sensors etc
