Home > General > towing 3.5 tons
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
towing 3.5 tons
2006 Sport. I am going to have to tow a 3.5 ton trailer for about 4 miles (quite hilly). What would be the best driving strategy using the various gearing facilities the car offers?? Advice please. Andrew Kennedy
Post #617112 Thu Sep 09 2021 1:16pm
Dave B
Use Sport mode, but be gentle with the throttle.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #617118 Thu Sep 09 2021 4:20pm
andrew kennedy
Hi Dave B. Thanks for yours! Mine is a 2006 Sport, no Sports Mode? Andrew Kennedy
Post #617123 Thu Sep 09 2021 6:04pm
Is this on the public road? Just drive normally but give yourself plenty of extra time. No big accelerations and no big braking episodes. You can use the gearbox in manual mode to help on downhill sections along with the brakes. Start any descent slowly and keep the speed down all the way down the hill. Gentle braking but don't ride the brake or you'll cook them.
If it's really hilly, you might even need to use low range. 2012 SDV6 - it's missing a couple of cylinders
Post #617125 Thu Sep 09 2021 7:49pm
Pufftmw
Just drive normally in hi range but take corners a bit wider and take things slower. I do a lot of towing in my hilly part of Wales and its no different to standard driving, except when you meet someone coming the other way on a single-track road Smile
Post #617127 Thu Sep 09 2021 8:13pm
garrycol
Australia
Why doesn't it have Sport mode - all RRS have sport mode. Just move the gear lever to the left and you are in sport mode - the Sport indication will come up on the dash under the digital oddometer. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #617130 Fri Sep 10 2021 2:11am
IanV8
Scotland
Land Rover recommend starting in low range when towing heavy loads.
Ian 2018 Indus Silver SDV6 Autobiography normally towing a Buccaneer Cruiser.
Post #617134 Fri Sep 10 2021 8:34am
The beauty of the LR system is that starting in low and changing up to high range on the move is easy to do. It'd be worth doing if on an up hill start, certainly. 2012 SDV6 - it's missing a couple of cylinders
Post #617142 Fri Sep 10 2021 1:23pm
