Home > General > towing 3.5 tons |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
Use Sport mode, but be gentle with the throttle.
Thu Sep 09 2021 4:20pm |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 317 |
Hi Dave B. Thanks for yours! Mine is a 2006 Sport, no Sports Mode? Andrew Kennedy |
Thu Sep 09 2021 6:04pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Is this on the public road? Just drive normally but give yourself plenty of extra time. No big accelerations and no big braking episodes. You can use the gearbox in manual mode to help on downhill sections along with the brakes. Start any descent slowly and keep the speed down all the way down the hill. Gentle braking but don't ride the brake or you'll cook them.
Thu Sep 09 2021 7:49pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Just drive normally in hi range but take corners a bit wider and take things slower. I do a lot of towing in my hilly part of Wales and its no different to standard driving, except when you meet someone coming the other way on a single-track road |
Thu Sep 09 2021 8:13pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Why doesn't it have Sport mode - all RRS have sport mode. Just move the gear lever to the left and you are in sport mode - the Sport indication will come up on the dash under the digital oddometer. 07MY RRS TDV6 Arctic Frost Aspen Interior |
Fri Sep 10 2021 2:11am |
IanV8 Member Since: 06 Jan 2020 Location: Dunfermline Posts: 60 |
Land Rover recommend starting in low range when towing heavy loads.
Fri Sep 10 2021 8:34am |
The beauty of the LR system is that starting in low and changing up to high range on the move is easy to do. It'd be worth doing if on an up hill start, certainly. 2012 SDV6 - it's missing a couple of cylinders
Fri Sep 10 2021 1:23pm |
