Home > General > Tdv8 3.6 sump
Jefus957
Tdv8 3.6 sump
Hi, trying to find out what the plate at the bottom of sump is for and if it can be removed to do oil change as the sump plug is toast thanks
Post #616825 Thu Aug 26 2021 7:51pm
jimbg
Use a vacuum pump to suck the oil out? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #616826 Thu Aug 26 2021 7:56pm
There are two drain plugs on the TDV8. Both should be used. If the lower one is stuffed, how about draining the other one and then using a suction pipe down the dipstick to get out the remainder? 2012 SDV6 - it's missing a couple of cylinders
Post #616828 Thu Aug 26 2021 8:12pm
Jefus957
Tdv8 sump
Thanks for reply Iv'e already tried sucking oil out via dip stick but its only removed a couple of pints have thought of removing oil temp sensor to drain it that way
Post #616833 Fri Aug 27 2021 8:14am
As said, there are two drain plugs so it might be worth using the other one and seeing how much you get out.
I did wonder about the temperature sensor but no idea how easy it is to damage it etc. 2012 SDV6 - it's missing a couple of cylinders
Post #616835 Fri Aug 27 2021 8:50am
Jefus957
Perceived with the suction pump and after what seemed like forever finally got the oil out poured some fresh oil in and sucked that out aswell so now its replace turbo drain plug the filter and top up with oil thanks for comments 👍
Post #616841 Fri Aug 27 2021 7:38pm
