Home > Technical > Sat nav showing on drivers binnacle
Kevin-t
Hi Guy's.
Just Slowly getting used to some of the tech in my new to me RR-Sport A/B.
Coming from a really outdated 2004 discovery 3, the tech in the 2016 sport is mouthwatering!
Have a couple of things I just cannot fathom out tho! if anyone can help?
1....Driving home last night, Sat nav set to home destination a sat nav screen appeared in my drivers binnacle, only for a min.. or two. I cannot seem to be able to find out how it came on, can it be on permanently, or does it just come on in certain settings.
Plenty of info on the net also YouTube re: sat nav. However cannot seem to be able to find anything to link them, sat nav to binnacle.
2... If I open the boot with the fob, it won't close by touching the close button on the boot. I have to use the fob to close. No big deal...Just wondering again if its faulty or meant to be like that??
Thanks in advance.
Regards.
Kevin-T....................................
Post #616565 Fri Aug 13 2021 3:18pm
Turdmon
Not got my RRS to hand, but if you are using the factory nav, when it’s time for a manoeuvre it brings up a pictogram in the centre of the display to tell you where to go. You can set the screen to full screen map and I think this is done in themes within the display settings using the steering wheel controls. Mine is 2017 with Incontrol Pro, so yours could be different. Hope that helps.
Post #616566 Fri Aug 13 2021 4:51pm
