![]() | Home > Technical > Sat nav showing on drivers binnacle |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 129 ![]() ![]() |
Not got my RRS to hand, but if you are using the factory nav, when it’s time for a manoeuvre it brings up a pictogram in the centre of the display to tell you where to go. You can set the screen to full screen map and I think this is done in themes within the display settings using the steering wheel controls. Mine is 2017 with Incontrol Pro, so yours could be different. Hope that helps. |
