Home > General > 2012 L320 - High or Low Suspension for day to day driving? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8953 |
There are three basic heights: access, normal, off road.
Tue Jul 20 2021 11:46pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4952 |
I put together a PDF copy of the Owner's Handbook and Quick Start Guide for the 2012/13 cars, which you can download from here if you wish.
Wed Jul 21 2021 12:40am |
Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43 |
Wow, thanks for this reply, very useful and good to know. Cheers |
Wed Jul 21 2021 9:17am |
Many thanks for this Col, I'll have a flick through some of the sections while I wait for the hard copy to come through |
Wed Jul 21 2021 9:18am |
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 |
I never knew this and had been doing so - just without the brake on. Thank you |
Wed Jul 21 2021 12:17pm |
Never bothered about vehicle moving, only ever changed it with brakes off and transmission in neutral if I've wanted to change it, although never really use it that much.
Wed Jul 21 2021 12:30pm |
Yes Col, brakes off, transmission in neutral is just as good, but I to tell people to do it on the move as many sit with a foot on the brake unconsciously when stationary with the engine running. By moving slowly, you know nothing is going to get stressed in the suspension. 2012 SDV6 - it's missing a couple of cylinders
Thu Jul 22 2021 9:16am |
If you park up on a level bit of road, put the handbrake on, wind down the window, get out and then reach in through the open window (suspension won't move with the door open), you can watch the front wheel rotate ever so slightly as it moves through the heights. It's not much, admittedly, but if it wants to move then there will be a lot of torque built up somewhere if it's prevented from moving. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Jul 22 2021 9:22am |
thegolffather Member Since: 07 Jun 2024 Location: Guam Posts: 12 |
What setting do we set the RRS from the control buttons inside? I do not have an owners manual sorry |
Tue Aug 27 2024 6:27am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4913 |
Just leave them alone.
Tue Aug 27 2024 7:19am |
