Home > General > Centre console fridge - always leave on?
Agent_Trig
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Should this be left on all the time? Or only when using it?
Daft question, but guessing the switch is there for a reason... Confused
Post #615961 Tue Jul 20 2021 9:47pm
Only when using it, in my case. Can't see the point of using fuel to cool an empty box for no purpose. 2012 SDV6 - it's missing a couple of cylinders
Post #615962 Tue Jul 20 2021 10:29pm
Agent_Trig
I thought that might be the case. Fridges are fairly power hungry appliances.
Post #615963 Tue Jul 20 2021 10:48pm
It's not really a fridge as such, just a Peltier cooling device and an uninsulated box. 2012 SDV6 - it's missing a couple of cylinders
Post #615970 Tue Jul 20 2021 11:50pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I leave mine off all the time and find the cans left almost permanently inside (until drank) stay much cooler than if in the cabin on a hot day. If on a run and I do turn the fridge on I find it cools pretty quickly too. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #616011 Wed Jul 21 2021 9:08pm
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Mines on near constantly..... great for small drinks or pork pies Very Happy
Post #616013 Wed Jul 21 2021 9:22pm
scrumps
RRSTDV8,
I’m pretty sure this 19MY L494 AB and my last 16 MY had a “fridge” fitted as it’s an extra over a “cool box”.
I’ve just had it replaced under warranty as the compressor became noisy.
I assume that’s the reFRIDGErant compressor!
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #616180 Tue Jul 27 2021 6:57pm
Scrumps, you may have a fridge as it has been an option more recently. In 2012, the cool box was purely a Peltier type cooler, not a fridge. 2012 SDV6 - it's missing a couple of cylinders
Post #616190 Wed Jul 28 2021 8:02am
garrycol
Australia
Re: Centre console fridge - always leave on?
Use it only when you want it as it will drain your battery in quick order - 12 to 18 hours depending on temps and battery condition.
They actually work quite well and it can cool a bottle or two just as quick as a proper fridge. Work even better if you put cool items in the fridge.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #616191 Wed Jul 28 2021 9:21am
On mine the fridge only switched on when the ignition is on, so even if you leave it on all the time, it only cools when the engine is running. --
Post #616193 Wed Jul 28 2021 11:12am
There was an issue with earlier versions where they could carry on drawing current even with the ignition off. I think they changed the design at some point. I seem to remember talk of a different colour light on the switch denoting the change. Green LED for old, Blue for later versions? It's been a while, so this is all a bit hazy. 2012 SDV6 - it's missing a couple of cylinders
Post #616195 Wed Jul 28 2021 12:23pm
garrycol
Australia
My fridge runs independent of the ignition which means drinks stay cold when the car is off - thankfully the fridge fan is noisy enough to hear when the car is switched off and serves as a reminder to switch it off when the car is no longer needed for the day.
I was tempted to connect through an ignition source and integrate a timed switch to allow it to run for a period of time once power was removed but I never got around to it. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #616205 Wed Jul 28 2021 3:31pm
