![]() | Home > General > Centre console fridge - always leave on? |
Only when using it, in my case. Can't see the point of using fuel to cool an empty box for no purpose. 2012 SDV6 - it's missing a couple of cylinders
Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43 ![]() ![]() ![]() |
I thought that might be the case. Fridges are fairly power hungry appliances. |
It's not really a fridge as such, just a Peltier cooling device and an uninsulated box. 2012 SDV6 - it's missing a couple of cylinders
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
I leave mine off all the time and find the cans left almost permanently inside (until drank) stay much cooler than if in the cabin on a hot day. If on a run and I do turn the fridge on I find it cools pretty quickly too. 13MY Range Rover Sport Autobiography SDV6 - mine
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 ![]() ![]() ![]() |
Mines on near constantly..... great for small drinks or pork pies |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 546 ![]() ![]() |
RRSTDV8,
Scrumps, you may have a fridge as it has been an option more recently. In 2012, the cool box was purely a Peltier type cooler, not a fridge. 2012 SDV6 - it's missing a couple of cylinders
Use it only when you want it as it will drain your battery in quick order - 12 to 18 hours depending on temps and battery condition. They actually work quite well and it can cool a bottle or two just as quick as a proper fridge. Work even better if you put cool items in the fridge. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1181 ![]() ![]() ![]() |
On mine the fridge only switched on when the ignition is on, so even if you leave it on all the time, it only cools when the engine is running. --
There was an issue with earlier versions where they could carry on drawing current even with the ignition off. I think they changed the design at some point. I seem to remember talk of a different colour light on the switch denoting the change. Green LED for old, Blue for later versions? It's been a while, so this is all a bit hazy. 2012 SDV6 - it's missing a couple of cylinders
My fridge runs independent of the ignition which means drinks stay cold when the car is off - thankfully the fridge fan is noisy enough to hear when the car is switched off and serves as a reminder to switch it off when the car is no longer needed for the day.
