![]() | Home > Technical > 2010 ace help please |
Darrenh Member Since: 05 Dec 2020 Location: Aberdeen Posts: 10 ![]() ![]() ![]() |
Anyone any ideas please |
Are you saying the ARB actually pressurised and pulled one corner down?
Rear pipes are connected correctly (they can only go one way when grouped together)
Does the bottom pipe run from the pump? I think it does.
2 lower pipes go to the actuator
So at idle there should be no high pressure.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Britplumber (I think) did a post where he changed the front pipes with the body in site using high pressure fittings. Otherwise I think it has to be lifted. |
At idle, there should be low pressure. High revs, high pressure The valve block is fairly simple. Opens one valve at each end to counteract the body roll one way, and moves it again to counteract the other way (essentially. Its more complex in operation) The valves are not serviceable. They are integral to the block The system is capable of producing 150bar of pressure Front end needs a body lift to replace the pipes in one piece |
Found this;
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 ![]() ![]() ![]() |
Sorry to jump on, but mine was idling the other day and I leant on the front passenger side of the bonnet, and mine dropped. Maybe they do move at idle? |
Valve blocks off and clear.
Mine actually pulled down about 3-4 inch |
Same mate. I dont know why but it did. I was bumping it a bit, but still idle. Heard a creak so lent on and pushed.
