Home > Technical > 2010 ace help please
Darrenh
Hi i have a 2010 rrs 3.6 tdv8 with dynamic response.
I had a leaking rear ace pipe and rear anti rollbar
Iv replaced them filled the system up car at normal height.
Then after 20 seconds of running it pulled the front right corner down or pulled the rear left up then burst a front pipe.
Got a hydraulic shop to make up a repair section and then it did exactly the same again.
Lower of the 4 pipes grouped in the right front wheel area.
Has anyone a suggestion on what to do?
Post #615806 Thu Jul 15 2021 11:14pm
Darrenh
Anyone any ideas please
Post #615833 Fri Jul 16 2021 5:45pm
Brit Plumber
Are you saying the ARB actually pressurised and pulled one corner down?
At rest, there should be no pressure at either ARB. The pump should pump fluid to the block and back to the reservoir. Are you sure the rear pipes are connected to the correct locations? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #615926 Mon Jul 19 2021 8:26pm
Darrenh
Rear pipes are connected correctly (they can only go one way when grouped together)
new pipes and bar.
And yeah its sat still in neutral at idle
Heights are all calibrated correctly
Only error it throws is low pressure when the lower pipe bursts the flexible section.
Post #615935 Mon Jul 19 2021 11:22pm
Brit Plumber
Does the bottom pipe run from the pump? I think it does.
At idle, the pump runs but the valve block is closed and the pressure is returned to the reservoir. If it’s the pump to block pipe that’s bursting, it suggests that you have a blockage and the fluid can’t return, however I’d expect a high pressure DTC.
So, the comment about a corner going up or down is interesting. At idle that should never happen as the valve block should be closed. For that to happen, a valve has to open which suggests a possible valve issue. Perhaps a seized valve?
I have a home made kit I used to open the valve block and bleed the ARBs, that would confirm if the valves were working. Did you bleed the ARBs? If not, that could possibly cause the ARB to rotate one way as it could have got pressure to one side only. 2019 5.0 SC SVA (Current)
Post #615938 Tue Jul 20 2021 7:40am
Disco_Mikey
2 lower pipes go to the actuator
Top pipe to reservoir
2nd pipe from top is feed from the pump
Edit: when looking in the wheelarch
At the valve block end, both top pipes go to the actuator
Innermost pipe is feed from pump
Post #615942 Tue Jul 20 2021 9:04am
Darrenh
So at idle there should be no high pressure.
Is the valve block a simple left/right system?
Originally the rear right ace pipe was leaking constantly from the right hand side fitting onto the ram so both rears was changed but snapped bolts for the pipes on the arb
So would a stuck valve be a whole new valve block?
Can it be tested?
What operating pressures is the ace system subject too?
I did a part body lift to do the pipes and the seals can i do that again for front pipes?
Post #615959 Tue Jul 20 2021 8:47pm
Oldandconfused
Britplumber (I think) did a post where he changed the front pipes with the body in site using high pressure fittings. Otherwise I think it has to be lifted.
Post #615966 Tue Jul 20 2021 11:03pm
Disco_Mikey
Can it be tested?
At idle, there should be low pressure. High revs, high pressure
The valve block is fairly simple. Opens one valve at each end to counteract the body roll one way, and moves it again to counteract the other way (essentially. Its more complex in operation)
The valves are not serviceable. They are integral to the block
The system is capable of producing 150bar of pressure
Front end needs a body lift to replace the pipes in one piece
Post #615972 Wed Jul 21 2021 6:54am
Oldandconfused
Found this;
https://www.rrsport.co.uk/forum/topic55087.html
Pics of Brit Plumbers work on p1
Post #615984 Wed Jul 21 2021 10:05am
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Sorry to jump on, but mine was idling the other day and I leant on the front passenger side of the bonnet, and mine dropped. Maybe they do move at idle?
Post #615990 Wed Jul 21 2021 11:45am
Darrenh
Valve blocks off and clear.
Assume its the valves on top that control fluid direction?[/img]
Post #616002 Wed Jul 21 2021 4:49pm
Darrenh
Post #616003 Wed Jul 21 2021 4:50pm
Darrenh
Mine actually pulled down about 3-4 inch
Post #616007 Wed Jul 21 2021 6:10pm
Bertbuckie
Same mate. I dont know why but it did. I was bumping it a bit, but still idle. Heard a creak so lent on and pushed.
Possibly nothing to do with your issue, just thought I would mention it as others say its not on at idle.
Post #616010 Wed Jul 21 2021 7:27pm
