Home > General (L494) > Wading depth
HaggisMan
Wading depth
The recent torrential rain and flash floods in Glasgow and Edinburgh got me wondering what the limiting factor is on the 850mm wading depth of a RRS. Given the FFRR, Defender and Discovery all have 900mm, it seems odd they didn’t/couldn’t make the RRS the same. Presumably there’s some component or intake that’s not quite as high up or waterproofed on the RRS, so does anyone have any info?
Post #615491 Tue Jul 06 2021 11:12am
scarey
in the great scheme of things 5cm isnt that much difference ..factor in the bow wave and you get my drift.
Post #615492 Tue Jul 06 2021 11:43am
It's probably something like the height of the gearbox and transfer box breathers. They'll be slightly lower in the RRS simple because the vehicle isn't quite as tall at the back of the engine bay - the FFRR and D5 are a bit higher in the bonnet so giving more height for breathers to be placed higher up.
To be brutally frank, no one should be driving their vehicle through flood water over a couple of feet deep unless it's life and death so it's a bit moot. If you're getting near the wading depth of any of the big Landies these days then you're already out of your depth. Way too easy to drop the wheels in to an unseen dip/lifted manhole cover, hit some semi-submerged debris being taken along by the water, etc. Do that and you're going to be in need of rescue. Do it in water that's a foot or so deep and you'll probably get away with it. Do it in nearly 3 ft of water and you're risking a write off. I'm not suggesting that anyone here would be so blasé but watching news footage of people driving through flood water, you do see people being amazingly stupid. 2012 SDV6 - it's missing a couple of cylinders
Post #615493 Tue Jul 06 2021 11:57am
1richard1
Or fit a snornkel then you would really have to be in over your head to get a problem.
Post #615505 Tue Jul 06 2021 5:22pm
jimbg
Interesting video on the Discovery's air intake system
https://jalopnik.com/the-2017-land-rover-d...1793607086 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #615506 Tue Jul 06 2021 5:31pm
Punkawallah
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Adriatic Blue
That is genuinely interesting!
Post #615507 Tue Jul 06 2021 5:47pm
riverblanche
Hi,
I think it is simply the ride height, in highest setting the RRS sits a bit lower so the max height is lower.
dont forget to walk any flooded area first to check for hidden obstacles or open man hole covers Whistle
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #615508 Tue Jul 06 2021 6:10pm
Interesting. I note that the intake in the wing isn't actually sealed. He says "this seals it" but if you look the bonnet gap is unsealed above the entry in to the wing so water could just go straight it. I guess that's why they have a water trap later in the intake route too. 2012 SDV6 - it's missing a couple of cylinders
Post #615534 Wed Jul 07 2021 8:37am
the issue is not waterproofing, you could probably wade in 1m and still be fine.
the problem with the L494 and wading, is that if you go in too deep, the car will start floating and you will lose control.
hence why they have water-absorbing stuff in the door sills, but that also has its limits.
here's an example:
Post #615537 Wed Jul 07 2021 8:50am
Floating has always been a problem. I remember chatting to the guys at LRE Eastnor before the L405 FFRR was launched. The engineers had been trying to get as much wading depth as possible but it kept floating. I guess that's one reason there is a 900mm limit - much more and you turn in to a boat skipper, not a car driver! Shocked Laughing 2012 SDV6 - it's missing a couple of cylinders
Post #615540 Wed Jul 07 2021 9:49am
flydive
I would hate to "find" an open man hole cover while walking the flooded area Wink '08 RRS TDV8
Post #615564 Thu Jul 08 2021 2:52pm
ecs0set
I drove my D4 through a river crossing that was deeper than expected and can confirm floating is the main issue! It automatically engaged extended mode and we quickly hit a slightly shallower section just 60cm downstream but it was scary af and I would never go wading beyond the top of the alloy again.
Post #615591 Fri Jul 09 2021 6:21pm
peterjj
Australia
More than just a manhole cover can be missing under floodwater. This low level crossing looked passable because the water seemed only a bit higher than the road level. Or so I heard. (not me in the picture)
 Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #615603 Sat Jul 10 2021 8:51am
