Home > General (L494) > MY17 SDV6 Crankshaft issue?
Page 1 of 3 123>
TimD
Hi all.
I'm in the market for either an X5 40D or a RRS Autobiography, and currently teetering on the edge of getting a 2017 3.0l SDV6 RRS with 35000 on the clock, but having massive reservations having read so much about the crankshaft issues! (And needing a new engine to fix)
Does anyone know if this issue is with early models, and mainly TDV6, or if its still and issue with a MY17 SDV6 (67 plate)?
Any help/insight would be massively appreciated as I'm loathed she'll out on a big risk.
Thanks, Tim
Post #614991 Mon Jun 21 2021 12:01pm
m13lky
Tim,
The risk is the same with every sdv6 engine from what I know. If you go ahead I would only buy an approved used & it should have a full service history by JLR, even then the warranty probably won’t pay out but JLR normally pay out as a good will gesture.
Good luck!
Malc
Post #614993 Mon Jun 21 2021 12:37pm
Or buy the V8 diesel or V8 petrol. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #614994 Mon Jun 21 2021 1:39pm
TimD
ooh, so the 4.4 SDV8 isn't affected then?
I was pushing for a MY17 for the updated and way better inControl touch pro, but maybe a late 2015 V8 might work! Smile
Post #614996 Mon Jun 21 2021 2:18pm
Spleen
Bought mine at 16k miles and nearly 44k miles later my crankshaft is still very much intact... Ferrari F430 Spider F1
MY17 RRS AB V6
2CV6 Special
Post #614998 Mon Jun 21 2021 3:14pm
harisson
Switzerland
as mentioned here, all SDV6 CAN have this issue.
the problem is, that you can't find out if it will come or not.
I have read a statement of a mechanic, who mentioned, that all crankshaft issues he has seen, were combined with low / very low oil level. Range Rover Sport HST D350
Post #614999 Mon Jun 21 2021 3:21pm
My SDV6 has nearly 120k miles on it and so far , so good. Ooh, I hope that isn't tempting fate... Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #615001 Mon Jun 21 2021 3:35pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Mines a 2015 year but MY16 model and they have a few more toys than the MY15 15 plate cars. Gesture tailgate and automatic passenger access(lowers the car when you pull up)are a couple of things but I’m sure there are more updated items. Mine is also the V6 and 42k on clock with no issues as yet……This is also the best car I have had and have no plan’s to change it yet. This is my2nd RRS and to me there is no better SUV on the market.
Post #615007 Mon Jun 21 2021 5:31pm
Ash3
Would that not suggest that this is result of oil leaking somewhere ?
How else can you get low oil unless insufficient oil was put in during a service.
BMWs when they suffer oil dilution they give a "oil level roo high" message and recommend oil to be drained to correct level.
From what I hear its not just range rovers that suffer oil dilution .....do BMWs suffer crank shaft failures or audus or mercs?
Post #615018 Mon Jun 21 2021 8:22pm
Oil burning would also cause a low oil level. Or it's just not being filled correctly thanks to the silly electronic dipstick that is sadly becoming ubiquitous. There is no oil level warning light, amazingly, only an oil pressure warning.
I wouldn't be surprised if some vehicles are being run on ever lower oil levels with each service - would be easy to put in slightly less than was taken out, for example - and that is leading to them running with low oil levels. 2012 SDV6 - it's missing a couple of cylinders
Post #615032 Mon Jun 21 2021 10:35pm
harisson
Switzerland
hi Ash
I don't know from where the low oil level is coming. I checked every ca. 1000km the oil level and it was everytime full / nearly full in my MY16 SDV6.
I also have given my car on time in service. not everybody is on time and is "stretching" the time and kilometers..
every Diesel car can suffer from oil dilution - it depends of your driving style and the architecture of the engine, exhaust and DPF.. I suppose that a lot BMWs, Audis and Mercs suffer from oil dilution and the most drivers don't care, because they don't know it and German premium cars have 24months service interval or 30'000km distance. during discussions with friends etc. I have seen that ALL are giving the cars in service after 24 months. their argumentation "the manufacturer says so.."
IMHO the worst thing what you can do to your engine...
If I check the technical specs of the new I6D engines, then I see that JLR has setup the engine with 8.8l oil volume. I suppose to minimize the oil dilution impact (2 decilitre of Diesel in oil are in percentage muss less in a total oil volume of 8.8l then 5.9l Smile )
the new I6D has also a 24 month service interval or a service distance of 34'000km.
I will, for sure, do an oil change every 12months or more/less 12'000-15'000km Range Rover Sport HST D350
Post #615046 Tue Jun 22 2021 8:20am
TimD
What month 2015 is it John - seen an end of September 2015 (65) plate. Would that be. MY16 do you think?
Also, any idea when the MY17 was first seen with the touch pro - just wondering if a 66 plate might have it!
Post #615054 Tue Jun 22 2021 1:44pm
Spleen
Mines a 66 MY 17 and has InTouch Pro. I deliberately went for that because the old one is just horrible, ITP still isn't a patch on my old BMW's iDrive. Ferrari F430 Spider F1
MY17 RRS AB V6
2CV6 Special
Post #615056 Tue Jun 22 2021 4:13pm
Johnrrs
Mine was registered July 2015 so one of the first MY16 models. It also takes adblue which is another give away that it’s the MY16. I think there are more options and colours available on the MY16 too like head up display and Zanzibar silver (my colour). All the differences are on this forum somewhere and there are also PDF sales brochures for every year somewhere too so that will tell you all changes/updates for the 15/16 and 17 year models.
Post #615057 Tue Jun 22 2021 4:19pm
unless you like sleeping with a grenade under your pillow, get the SDV8 or the V8 Supercharged Thumbs Up
seen this morning: https://www.lrukforums.com/threads/engine-...st-1762461
"...crank shaft on my 2012 RRS SDV6 160,000kms went this week ..." --
Post #615075 Wed Jun 23 2021 7:09am
Page 1 of 3 123>
