Home > Faults & Fixes > Unidentified leak
tess
Unidentified leak
From looking at the driveway, the leak is not water based washer fluid or coolant & its looks its coming from the floor underneath the drivers seat, any ideas?
Post #614505 Tue Jun 08 2021 12:35pm
Disco_Mikey
Fuel filter lives in that area Thumbs Up
Post #614512 Tue Jun 08 2021 1:53pm
Brit Plumber
ARB pipes possibly? Is the liquid oil like or petrol like? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #614514 Tue Jun 08 2021 2:00pm
tess
The fluid isn't a rainbow more like oil
Post #614518 Tue Jun 08 2021 2:07pm
tess
The leak maybe from the rear diff, is that just seals?
Post #614600 Wed Jun 09 2021 8:13pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
What does it smell like? If diesel rather than oil then as Disco Mikey says the fuel filter is under there or alternatively it may be a leak from the FBH pump or pipework which is nearby, slightly in front of the drivers seat and towards the middle. I had a leak from there although in your case the Fuel Burning Heater pump shouldn't be working in the summer so less likely! 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #614605 Wed Jun 09 2021 8:46pm
Brit Plumber
That’s just a little distance from the drivers seat area! 2019 5.0 SC SVA (Current)
Post #614610 Wed Jun 09 2021 9:49pm
It's not just condensate from the air conditioning, is it? 2012 SDV6 - it's missing a couple of cylinders
Post #614628 Thu Jun 10 2021 12:37pm
tess
If it was condensate, wouldn't it evaporate in this weather & the fluid feels like oil in my fingers
Post #614642 Thu Jun 10 2021 6:47pm
If it's oily, it's either fuel or dynamic response fluid. Fuel has an obvious smell, dynamic response fluid isn't smelly in small amounts.
The dynamic response valve block is under the driver's side cill, the pipes run to and from it along the cell. The front and rear anti roll bars are known to leak.
Needs putting on a ramp and having a good look at.
It could also be transfer box or gearbox fluid but again it needs to be jacked up and a good look around. 2012 SDV6 - it's missing a couple of cylinders
Post #614645 Thu Jun 10 2021 7:35pm
tess
The oil leak is from the rear diff area, is this a repair or replacement
Post #614813 Wed Jun 16 2021 10:52am
tess
Mystery solved, the rear anti roll bar is leaking.
Post #615055 Tue Jun 22 2021 3:33pm
