Home > Faults & Fixes > Unidentified leak |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4412 |
Fuel filter lives in that area |
Tue Jun 08 2021 1:53pm |
ARB pipes possibly? Is the liquid oil like or petrol like? 2019 5.0 SC SVA (Current)
Tue Jun 08 2021 2:00pm |
tess Member Since: 20 Feb 2020 Location: sheffield Posts: 32 |
The fluid isn't a rainbow more like oil |
Tue Jun 08 2021 2:07pm |
The leak maybe from the rear diff, is that just seals? |
Wed Jun 09 2021 8:13pm |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
What does it smell like? If diesel rather than oil then as Disco Mikey says the fuel filter is under there or alternatively it may be a leak from the FBH pump or pipework which is nearby, slightly in front of the drivers seat and towards the middle. I had a leak from there although in your case the Fuel Burning Heater pump shouldn't be working in the summer so less likely! 2010 TDV8 - current - my first RRS, loving it so far......
Wed Jun 09 2021 8:46pm |
That’s just a little distance from the drivers seat area! 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Wed Jun 09 2021 9:49pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
It's not just condensate from the air conditioning, is it? 2012 SDV6 - it's missing a couple of cylinders
Thu Jun 10 2021 12:37pm |
If it was condensate, wouldn't it evaporate in this weather & the fluid feels like oil in my fingers |
Thu Jun 10 2021 6:47pm |
If it's oily, it's either fuel or dynamic response fluid. Fuel has an obvious smell, dynamic response fluid isn't smelly in small amounts.
Thu Jun 10 2021 7:35pm |
The oil leak is from the rear diff area, is this a repair or replacement |
Wed Jun 16 2021 10:52am |
Mystery solved, the rear anti roll bar is leaking. |
Tue Jun 22 2021 3:33pm |
