Home > Faults & Fixes > Shine some light on my faults
JamieLC
Hi guys. Please could anybody shine some light on these faults that were highlighted during my service.
I asked the garage to plug it in to see if anything came up. No issues with the car, all seems to be running fine so I found this strange:
Speed control - intermittent fault
U0401 invalid data from engine control module.
Gear shift module
U0422 intermittent invalid data from BCM
Keyless entry
U3000 intermittent data control module
Image processing - historic
U0447 invalid data received from gateway ‘A’
The bloke in the garage is going to look into it also but thought I’d ask on here, thanks 2016 Yulong White L494 AB/DYN 3.0SDV6
Post #613535 Tue May 11 2021 7:46pm
Benrrs2021
Looks fairly standard to me 😂
I have found the car can throw alsorts of errors for no reason at all.
Sometimes the odd sensor is just a little slow to respond and it logs a fault.
If you dont have a light on i wouldnt worry about them. Clear them and see if anything comes back as a first try.
Post #613544 Wed May 12 2021 7:07am
JamieLC
Yes the mechanic mentioned a similar sort of thing, they are clear now so will pop it back on next week and see what we have. I’m getting ARB bushes changed as I can’t handle the low speed knock any longer 😂 2016 Yulong White L494 AB/DYN 3.0SDV6
Post #613546 Wed May 12 2021 7:16am
gogsy1956
Unless they're causing a problem forget about them and call yourself lucky Rolling with laughter 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #613563 Wed May 12 2021 12:49pm
Those are simple communication error messages that aren't usually a cause for concern, so long as they're not happening constantly and repeatedly. 2012 SDV6 - it's missing a couple of cylinders
Post #613564 Wed May 12 2021 1:11pm
Brit Plumber
As a U prefix code, ignore them, if they had other associated codes and you had a problem, then you’d want to look into it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #613587 Thu May 13 2021 6:25am
