![]() | Home > Faults & Fixes > Shine some light on my faults |
Benrrs2021 Member Since: 03 May 2021 Location: Morecambe Posts: 14 ![]() ![]() ![]() |
Looks fairly standard to me 😂
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 ![]() ![]() |
Yes the mechanic mentioned a similar sort of thing, they are clear now so will pop it back on next week and see what we have. I’m getting ARB bushes changed as I can’t handle the low speed knock any longer 😂 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Unless they're causing a problem forget about them and call yourself lucky |
Those are simple communication error messages that aren't usually a cause for concern, so long as they're not happening constantly and repeatedly. 2012 SDV6 - it's missing a couple of cylinders
As a U prefix code, ignore them, if they had other associated codes and you had a problem, then you’d want to look into it. 2019 5.0 SC SVA (Current)
