Home > General (L494) > Deployable Side Steps Motor
Welshian
Wales
My nearside Deployable Side Step is stuck out and I suspected that it was seized, however, on investigation that does not seem the case as the folding brackets move freely. Is there a procedure for removing the drive motor as it looks as if some of the trim must be removed first to gain access. RRS2 HSE Chile Red
1955 Morris Minor lovingly fitted every nut and bolt
Post #613458 Sun May 09 2021 4:36pm
3hcp
Stuck step
Did you ever get to the bottom of the problem as I have the same fault. 2015 RRS DIESEL HYBRID
Post #625258 Thu Jul 07 2022 12:51pm
