Home > Technical > Restricted performance
Harry1234
England 2010 Range Rover Sport TDV8 HSE Santorini Black
This is an update to my previous thread ‘black smoke from one exhaust’ the restricted performance came on when out shopping, however went off when restarted, plugged it in when got home and fault code p0281 cylinder 7 contribution/balance came up, has anyone had this fault? Also it has an horrendous hesitation when setting off at traffic lights, junctions etc... if engine is cold it’s even undrivable . Any help would be appreciated.
Post #613226 Tue May 04 2021 7:20am
Any help? unless of course you already have the info.
Post #613231 Tue May 04 2021 10:00am
Harry1234
Hi Col, thanks for the info, I will do some investigating. Cheers Harry
Post #613237 Tue May 04 2021 10:36am
Harry1234
Update, it is clear that number 7 injector has already been replaced, so someone knew of the issue, so guna do a compression test as this is more likely to be something more serious, is it easy enough to do a compression test or should I book it in, I’ve got a test for petrol but never done a diesel
Post #613242 Tue May 04 2021 12:29pm
