![]() | Home > Technical > Restricted performance |
Any help? unless of course you already have the info.
Harry1234 Member Since: 01 May 2021 Location: Doncaster Posts: 9 ![]() ![]() ![]() |
Hi Col, thanks for the info, I will do some investigating. Cheers Harry |
Update, it is clear that number 7 injector has already been replaced, so someone knew of the issue, so guna do a compression test as this is more likely to be something more serious, is it easy enough to do a compression test or should I book it in, I’ve got a test for petrol but never done a diesel |
