Home > Maintenance & Modifications > L320 early - can the headlamps faces be changed?
Stevepd
I thought the tops of my headlights are deteriorating so today I’ve had a proper look. On both sides they are failing on the inside at the tops of each light face. I’ve noticed the clips at the top, hence the question. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #612936 Sat Apr 24 2021 12:53pm
Devon Z
The simple answer is no for the early lights, you can the lenses for facelift.
I also thought mine were fading on the inside but no I bit the bullet and sanded and polished mine and they’ve come up alright, still need a bit of work but better.
Still a bit of crazing in the sunlight but the grey fading has gone, apparently it’s the UV coating which is damaged and needs sanding off then polish the plastic then keep coating with a UV protectant. Steve
1998 Volvo V70 R auto FWD, mothballed future project.
Post #612939 Sat Apr 24 2021 2:19pm
Stevepd
If I’m honest I had a go today with my micro mesh kit. Results were ok but not brilliant, best described as patchy. So I might bite the bullet and get one of these headlight restoration kits....... 2006 2.7 TDV6 HSE in Cairns Blue.
Post #612940 Sat Apr 24 2021 2:57pm
garrycol
Australia
The polycarbonate lens can be removed using a heat gun but you cannot buy replacements individually. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #612957 Sun Apr 25 2021 6:24am
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Tried with a kit, not happy with result.
After a search reading about options, new lenses impossible to find, sanded it all again and result was a white haze, then sprayed with uv resistant synthetic laquer - nearly 100% happy.
Post #613036 Tue Apr 27 2021 5:46pm
knwatkins
Due to a couple of scratches, I wet sanded my L320 ones with wet and dry paper working up through the grades to 2000 grit, then polishing compound afterwards, followed by a coating of Autoglym liquid hardwax. They came out absolutely perfect and didn't degrade over the next 12 months before I sold the car.
Cost would have been under a tenner a few hours beavering away in the shed. Kev
Post #613043 Tue Apr 27 2021 9:05pm
RobP
Replacement lenses for the L320 headlamp are something Powerful UK are working on developing but dont have a date for availability yet
This was the info I got from them about 2 weeks ago
If more people ask the question they might realise there is demand for them and speed up the development Thumbs Up TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #613402 Fri May 07 2021 10:51pm
Stevepd
Cheers Rob. I purchased an Autoglym headlight restoration kit but haven’t had the time or weather to do it yet, and at the mo it’s chucking it down. As these get older there bound to be a market for it although perhaps not a big one? 2006 2.7 TDV6 HSE in Cairns Blue.
Post #613407 Sat May 08 2021 6:52am
mgrover
id defo be interested in replacement lenses tbh.
Post #614365 Sat Jun 05 2021 3:39pm
garrycol
Australia
Well when you find some let us all know who makes them. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #614379 Sun Jun 06 2021 4:30am
Thewilbury
Ireland 2010 Range Rover Sport 3.0 TDV6 HSE Lux Stornoway Grey
https://www.powerfuluk.com/vehicles/range-...-left.html
Post #616249 Fri Jul 30 2021 11:00pm
Mafya
United Kingdom 2010 Range Rover Sport TDV8 HSE Lux Buckingham Blue
I have some facelift headlights bi xenon active cornering ones plus the rear clusters if anyone is looking for any as I have no use for them anymore. They are in good nick if anyone wants to upgrade their headlights…
Post #616250 Sat Jul 31 2021 2:27am
Unfortunately the Facelift headlamps will not fit the Pre-Facelift without changing the front wings/bumper etc. as well.
Post #616251 Sat Jul 31 2021 3:10am
Dunno how good these are
£68.33 48% Off | Headlight Cover for Land Rover Rang Rover Sport 2006 2007 2008 2009 Car Headlamp Lens Replacement Auto Shell
https://a.aliexpress.com/_m0tIblp
Post #616255 Sat Jul 31 2021 9:36am
£51.86 56% Off | Wooeight Car Replacement Auto Shell Cover Clear Shade Caps Car Headlamp Lens Fit For Land Rover Range Rover Sport 2005 2006-2009
https://a.aliexpress.com/_mOTuDIx
Post #616256 Sat Jul 31 2021 9:46am
