Home > General (L494) > Ctek Quick connector fitting |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
https://www.rrsport.co.uk/forum/topic57492.html
Wed Feb 10 2021 12:51pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
Cheers those the ones I saw. Was just thinking about going in the tail direcly to the battery was all as its more convenient to save running and extension lead was all.
Wed Feb 10 2021 1:12pm |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 89 |
Hello,
Wed Feb 10 2021 2:35pm |
HI Chap you got any pictures? I was thinking of getting another quick connect cable to add to the aux battery too. or was thinking if it was possible to split the splitter cable so power would be supplied to both batteries but thought it might confuse the charger as it wouldnt know when the smaller one as topped up
Wed Feb 10 2021 2:44pm |
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 37 |
I havent read the info on the link but if RRS AGM Battery it is usually advised NOT to charge battery directly |
Wed Feb 10 2021 8:55pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi,
Wed Feb 10 2021 9:25pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Fitting instructions if you want to buy the overpriced L/R branded Ctek kit or use the wiring diagram.
Wed Feb 10 2021 10:57pm |
Doh Col got there before me!
Wed Feb 10 2021 11:32pm |
Cheers col I’m doing the same just with the ctek and just using the basic cables plug they supply, their official kit wires direct to the battery under the floor, it’s the same unit as far a I am aware they just charge far more to put an LR logo on it😉 If a jobs worth doing, get a someone who knows what they are doing to do it!
Wed Feb 10 2021 11:39pm |
I think you are right the L/R kit is basically the MXS 5.0, the thing is you can buy the MXS 10.0 from amazon for a similar price but that's L/R for you, the 10.0 does have a couple of extra feature like a 12volt power supply, which can be handy when mucking around with the car if anybody wanted that little bit extra.
Wed Feb 10 2021 11:57pm |
jd2uk Member Since: 01 Apr 2017 Location: Kent Posts: 109 |
For those that have followed the LR instructions to fit the CTEK MXS 5.0 did you use the M6 or M8 quick connector kit? I don’t intend on cutting into the trim for a 12v socket and will just leave the quick connector loose in the spare wheel well unless anyone would advise against this?
Sun Aug 21 2022 10:21pm |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 463 |
I use a CTEC and just use the terminals under the bonnet. Like you say it charges both battery’s and it’s the only time the start stop system works as it should. After a few days of using car with no charging the stop start stops working. Is the alternator on these cars large enough to charge these batteries fully in normal day to day use. In the early days of having the car I took the car to the dealers to get the stop start checked out and all they did was put it on charge over night……. |
Mon Aug 22 2022 6:13am |
Has anyone actually followed the LR instructions? I've taken the spare wheel out and can't seem to locate the negative point used? It appears to be directly in front of the tool kit.
Mon Aug 22 2022 3:29pm |
