![]() | Home > Maintenance & Modifications > Oil Pipework Diagram |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
Have a look here - http://new.lrcat.com/ |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Any chance it is one of these? possibly the one marked. Could google PBP500091 and see if it looks like it.
Ziggy Member Since: 14 Jun 2017 Location: UK Posts: 12 ![]() ![]() ![]() |
Thanks Col, its actually the next pipe along - the one that connects to pipe 6N886D. Its leaking from the little plastic connector where the rubber hose joins to the metal pipe. |
O.K. if you mean this connection below try PBP500081 but I think you may find the plastic connector is part of the other rubber hose and not serviceable separately.
