Home > Maintenance & Modifications > Oil Pipework Diagram
Ziggy
United Kingdom 2005 Range Rover Sport TDV6 SE Java Black
Does anyone have the workshop manual diagram of the oil system / pipework for a 4.2 supercharged?
I'm trying to order a pipe from LR but they're struggling to get the correct part.
For reference its one of the rubber hoses that comes off the oil filter housing assembly and connects to the metal pipe(s) that continue under the engine. Confused
Thanks
Post #609725 Tue Feb 09 2021 11:38am
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Have a look here - http://new.lrcat.com/
Post #609732 Tue Feb 09 2021 2:33pm
Any chance it is one of these? possibly the one marked. Could google PBP500091 and see if it looks like it.
Post #609754 Tue Feb 09 2021 8:38pm
Ziggy
Thanks Col, its actually the next pipe along - the one that connects to pipe 6N886D. Its leaking from the little plastic connector where the rubber hose joins to the metal pipe.
Post #609759 Tue Feb 09 2021 10:55pm
O.K. if you mean this connection below try PBP500081 but I think you may find the plastic connector is part of the other rubber hose and not serviceable separately.
Post #609768 Wed Feb 10 2021 9:05am
