![]() | Home > General (L494) > Android screen upgrade |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 179 ![]() ![]() ![]() |
Hi SC
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1191 ![]() ![]() ![]() |
Mike, do you perhaps have a link to the unit you bought? thanks |
Here you go: -
thanks Mike.
I'm sure they are all made by Merryway, I see that the one you link to is now Android 10, I saw a review and it's supposed to load a bit faster than the Android 9 versions but otherwise the same.
Yep, I'm also on that forum.
Nothing hard about it, just take your time with the new display ribbon cable as it has to have a twist in it. They do provide a spare in with the kit just in case. The OEM PCB's just lift out and push back in to sockets with self locate so you can't really cock that up. |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
i did this route as i didnt want to pull the head unit about to much this is the next best thing and works really well
Downtime Member Since: 12 Mar 2021 Location: Tq121lj Posts: 4 ![]() ![]() |
Hi All,
duke41 Member Since: 25 Aug 2018 Location: PETERBOROUGH Posts: 21 ![]() ![]() ![]() |
Installed aftershock android 10..........excellent bit of kit ,i use autokit and its faultless,i still have all original features but never use them....as my iphone has unlimited data i use the TuneinRadio app that shows on carplay screen for my DAB....perfect. I installed the microphone from the unit which is only needed for siri and apps...(itunes,waze,maps,whattsapp,messenger,phonecalls etc) carplay handles phonecalls and uses the car speaker system perfectly. Had to adjust car eq and also android eq to bring meridian back to best levels...but there is no deterioration in sound and dolby/dts work as they did.
