Home > Technical > Heavy steering
lkdgndg1
Heavy steering
Is the steering supposed to be a bit on the heavy side on the Range Rover sport 2009 HSE model , as mine does seem to be a bit heavy going at low speed . Also the steering columb adjustment either man or auto doesn’t work at all and there does not seem to be a fuse to cover it , and ideas please would be nice.
Post #609447 Mon Feb 01 2021 10:06pm
Devon Z
Don’t know much about the electric steering column as mine doesn’t have it but the steering on mine is really nicely weighted, never heavy even at low speed but she’s only on 19’s. Steve
1998 Volvo V70 R auto FWD, mothballed future project.
Post #609448 Mon Feb 01 2021 10:20pm
lkdgndg1
Mines on 275/40/20 ,would that make the steering a bit heavy at low speed ?
Post #609491 Tue Feb 02 2021 10:51pm
Devon Z
I would expect so, I’m sure someone who has 20’s will be along to confirm. Steve
Post #609492 Tue Feb 02 2021 11:32pm
There is a relay (small ecu) marked ZF to make the steering light at low speeds.
It’s in passenger footwell.
And a solonoid on steering rack.
Have 22” 285? on mine (they were on it before I purchased it)
Nice and light at low speeds
Post #609494 Wed Feb 03 2021 7:16am
Disconnect steering rack connector.
Put a 5W bulb across connector and turn ignition on start engine.
Bulb should light.
If it lights, measure rack resistance
Post #609495 Wed Feb 03 2021 8:02am
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
Can’t say I’ve ever noticed heavy steering at low speed, regardless of tyre/wheel size. I run 20s on mine in summer and 19s in winter. Now I think of it, the steering in my 2010 Sport is lighter than many other saloon/estate cars I’ve had.
Edit: Meant to add that turning the wheel whilst manoeuvring in a car park/driveway etc is usually one hand only needed to turn the wheel from lock to lock. 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #609496 Wed Feb 03 2021 8:31am
lkdgndg1
Thanks for that Andy I’ll give it a go .
Post #609523 Wed Feb 03 2021 8:28pm
Eaters
My 2008 model is fine a slow speeds and I'm on the same size tyres as you. Steering feels good and I wouldn't have even thought about it but for your post. So it would suggest you have some sort of fault Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #609543 Thu Feb 04 2021 2:55pm
Paulsinhis30s
United Kingdom 2006 Range Rover Sport Supercharged Zambezi Silver
Mine is running the same tyre size as you, but the steering is not usually heavy.
However....
Last winter, my steering suddenly went very heavy, turned out it was a lack of lubrication in lower steering UJ, you can get to it relatively easy from underneath, maybe give that a try before getting too technical.
Post #609546 Thu Feb 04 2021 3:26pm
Oh yeah.
I think that fault means it gets stiff when hot
Post #609551 Thu Feb 04 2021 5:30pm
lkdgndg1
Had the bottom plates off today near the steering rack and found the electrical connector right off not even connected so cleaned it up and refitted and now steering nice and light , what a difference .
I now need to find out how to get the steering column electrical adjust and memory setting to work , I did hear that it may be something to do with the seat memory system but the seats all work ok .
Post #609629 Sat Feb 06 2021 6:00pm
Nice easy one Laughing
Try that setting where the seat and wheel move when you get out.
Turn the knob to auto to do this.
See if the seat moves but the wheel doesn’t.
I guess it could be unplugged. Laughing
The trim panel square comes off if you pull it from the bottom
Post #609635 Sat Feb 06 2021 6:29pm
lkdgndg1
I’ve tried it in the auto and man position and nothing, not even a sound from the steering column motors . If I press any of the memory buttons on the drivers seat the seat works fine but nothing from the steering side , there was an item on the USA Range Rover site that does mention having the dealer disable the steering column feature but surely the manual adjustment should still work , I’ll get to the bottom of this one way .
Post #609668 Sun Feb 07 2021 9:05pm
