Home > General > K seal vs steel seal
airc909
United Kingdom 2005 Range Rover Sport TDV6 SE Siberian Silver
Hi
Anyone able to advise which of these two products would be best to Use on a 3.6 tdv8 which is losing coolant ?
http://www.headgasketpro.com/head-gasket-r...teel-seal/
Thanks
Chris
Post #608989 Fri Jan 22 2021 2:24pm
Red Arrow
Both are good but the steel seal i would say would be better for yours Thumbs Up
Worth a try Thumbs Up
Post #608992 Fri Jan 22 2021 3:59pm
Disco_Mikey
Don't use either. They will both cause longer term issues Shocked
Post #609003 Fri Jan 22 2021 8:01pm
Please don't bodge a TDV8. It's a great engine that deserves respect not bodging to keep someone that can't afford to run it happy. Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #609024 Fri Jan 22 2021 11:26pm
airc909
Re: K seal vs steel seal
airc909 wrote:
Hi
Thanks
Chris
Thanks mate
Post #609028 Sat Jan 23 2021 1:15am
Father Jack
Have you had it checked in an indy garage for cause of the problem ? In my experience of these products they either don't work at all or very well. A diagnostic check at a garage to confirm the issue and solution would be a far better idea.
Post #609033 Sat Jan 23 2021 8:44am
