Home > Maintenance & Modifications > Best Quality EGR Valves?
MickS
It's cold and once again my EGR valves are playing up. Tried a cleaner with no luck so will have to replace - seen a few different sellers for these, can anyone recommend a good quality set that might actually last longer than two years.....
Thanks in advance
Mick
Post #608716 Sat Jan 16 2021 6:02pm
gogsy1956
Seeing it's the V6,, why not blank them off rather than replace, a lot easier compared to the likes of the V8 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #608743 Sun Jan 17 2021 12:44pm
MickS
Thanks for the reply, I have seen a lot of people saying this and am talking to my mechanic, but I am also aware that it is now against the law in the UK, so was looking for some advice on the best quality valves available.
Mick
Post #608839 Tue Jan 19 2021 1:37pm
Stevepd
If you fit the blanking plates and leave the pipe work in, nobody can visually see Whistle 2006 2.7 TDV6 HSE in Cairns Blue.
Post #608843 Tue Jan 19 2021 2:15pm
MickS
I can't find the post but sure someone said 2007 onwards would require a software patch to stop the Engine Management Light from coming on?
Mick
Post #608879 Wed Jan 20 2021 3:06pm
Stevepd
Yep I’m sure you’re right Thumbs Up . 2006 2.7 TDV6 HSE in Cairns Blue.
Post #608880 Wed Jan 20 2021 3:36pm
gogsy1956
Maybe I an wrong but I thought it was only the V8 that required a software update if blanking the egr's. Quite a common problem on the V6 but not so on the V8 2010 RRS, TDV8
22" overfinch
Post #608882 Wed Jan 20 2021 5:27pm
