![]() | Home > Technical > Do I need a new Battery on 2013 sport |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 952 ![]() ![]() ![]() |
I suppose it depends on how old the battery is,,, but first job would be to get it on a charger a couple of times a week as a 3 mile run ain't going to charge the battery 2010 RRS, TDV8
It's difficult to say without testing the battery. These vehicles are known to be heavy on the batteries. The cold weather just further compounds the strain on the battery, especially if you don't use the car for a while.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
I can highly recommend getting a decent charger and one of the tow electrics adaptors from the site shop, I probably run my FBH more than I do the car, so an easy convenient way to charge my battery is a god send, should also extend the life of you battery. MY12 RRS HSE
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
As shepp says. I use one of these and a CTEK mxs5, bearing in mind the low usage at the moment, short trips and cold weather (everything on hot!) I give it a trickle once a month or so. Even if your battery needs replacing, you can use the CTEK for other vehicles (ride on mower up to DB 1390).
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
