Home > Technical > Do I need a new Battery on 2013 sport
Demaske1
United Kingdom 2009 Range Rover Sport TDV8 HSE Arctic Frost
Hi all, I have a rrs sport 3.0 tdv6 and not used it much last couple of weeks apart from 3 miles to and from local supermarket. A Webasto heater is also fitted coming on twice daily for 20 mins at a time which normally comes on just before going to and from work but I forgot to switch timers off because I’ve been off work for a couple of weeks. Today went to start car and ignition lights etc but not enough to start. Borrowed a booster pack and fired up straight away. 3 miles to supermarket and standing for half an hour fired up no problem.
Do I need a new battery or is it just because it hasn’t been run far enough to charge the battery that has been drained because of the Webasto. Many thanks.
Post #608346 Fri Jan 08 2021 7:47pm
gogsy1956
I suppose it depends on how old the battery is,,, but first job would be to get it on a charger a couple of times a week as a 3 mile run ain't going to charge the battery 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #608347 Fri Jan 08 2021 8:05pm
knwatkins
It's difficult to say without testing the battery. These vehicles are known to be heavy on the batteries. The cold weather just further compounds the strain on the battery, especially if you don't use the car for a while.
If I were in your shoes, I'd buy a trickle charger (Ctek, Noco etc.) and when you aren't intending on using the car for a while, just pop it on to keep it topped up and see how it goes. Kev
Post #608348 Fri Jan 08 2021 8:09pm
shepp
I can highly recommend getting a decent charger and one of the tow electrics adaptors from the site shop, I probably run my FBH more than I do the car, so an easy convenient way to charge my battery is a god send, should also extend the life of you battery. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #608351 Fri Jan 08 2021 11:04pm
Oldandconfused
As shepp says. I use one of these and a CTEK mxs5, bearing in mind the low usage at the moment, short trips and cold weather (everything on hot!) I give it a trickle once a month or so. Even if your battery needs replacing, you can use the CTEK for other vehicles (ride on mower up to DB 1390).
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
Post #608358 Sat Jan 09 2021 10:58am
riverblanche
ISTR that the FBH will not fire up if the battery is low (timed climate or on its) there is a set of parameters that are checked before it starts and Voltage is one of them.
as said 3 miles each way no chance of adding charge,
I went food shopping on Friday which is 8 miles each way, I went the Long Way Round to give the car a run and 36 miles done (met no one and only shopped in Lidl)
Your temp gauge and some heat coming into the car after a mile or 2 but engine oil ect takes more like 20 min and 10+ miles to get up to temp Shocked
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #608368 Sat Jan 09 2021 3:51pm
