![]() | Home > Maintenance & Modifications > Anyone using SuperPro ARB Bushes-Updated |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
There's a difference in doing the anti-roll bar bushes (as Buckster has done) and doing the suspension arm bushes. The arms can be difficult to remove - sometimes the only way is to cut them off and then you need a new arm. One could change the bushes on the new arm for different ones, I suppose, but it's an added cost. Some fit aftermarket arms with improved bushes already fitted. Example of some of these here:
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 71 ![]() ![]() ![]() |
Hi
