![]() | Home > Technical > oil and seatbelt warning and low washer fluid warning |
Richie h Member Since: 29 Dec 2020 Location: downham market Posts: 2 ![]() ![]() ![]() |
Hi all, any help would be muchly appreciated,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Sounds a bit like a dodgy instrument cluster, which is not unheard off something about dry solder joints, sure someone will be along who has had a similar problem and be able to help with a bit more info.
gazmlrs Member Since: 01 Sep 2021 Location: Burnley Posts: 9 ![]() ![]() ![]() |
Yeah that's what I am thinking too... but some companies who repair the cluster suggested otherwise as its not normally these 3 things together. I have taken the cluster out and cleaned , checked wires and also checked the obvious earth points and cleaned them but still getting the errors. Think I might just have to order a cluster and see if these resolves the problem. really frustrating |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
80% cluster.
Thanks - I got a replacement cluster - (mileage was less incidentally) - had a garage move the data from the old cluster to the new and tried to reprogram using landrover sdd website… it failed when trying to install the software saying it couldn’t communication with the transfer/power train control unit - error A01
Hi Andy, I got a 2nd hand cluster same part / model etc! Fitted it the car and it had a hissy fit! Wouldn’t start, so put my old one back in and car won’t start now! Everything seems to work door locks, steering column - but the key just clicks and no crank, immobiliser light still flashing single while key in —- Any ideas?? It’s like the car is immobilised…. |
Ur I think the clue was here ![]() The code is the dash doesn't match the other 2 codes As to how you fix it now, I don't know. Wait a few hours? If that fails, disconnect battery |
