Home > Technical > oil and seatbelt warning and low washer fluid warning
Richie h
United Kingdom 2008 Range Rover Sport TDV8 HSE Siberian Silver
Hi all, any help would be muchly appreciated,
L320 TDV8 2008
so as the title suggests, For some time now, The oil warning light and seatbelt warning lights both come on at exactly the same time and also i get a low washer fluid warning.
Oil level is fine and also is the oil pressure (a friend of mine checked it with a scanner) needless to say, so is the washer fluid.
When these started, They went out quite quickly. But now there on for a good while and only go out after an hour or so of driving. Confused
has anybody else had this issue? what did you do to get it fixed?
Thanks
Post #607985 Tue Dec 29 2020 11:46pm
gazmlrs
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
@Richie h
Did you get this issue sorted? I have exactly the same problem. Just started with Instrument Panel shutting down and restarting as well. But the main issue at the moment is the Oil Warning light coming on and off, coincidently the low washer warning and seat belt warning too (when no-one is on the passenger seat).
@Here - can anyone provide advice on what the issue might be?
Post #616955 Thu Sep 02 2021 12:10am
Sounds a bit like a dodgy instrument cluster, which is not unheard off something about dry solder joints, sure someone will be along who has had a similar problem and be able to help with a bit more info.
Post #616959 Thu Sep 02 2021 3:12am
gazmlrs
Yeah that's what I am thinking too... but some companies who repair the cluster suggested otherwise as its not normally these 3 things together. I have taken the cluster out and cleaned , checked wires and also checked the obvious earth points and cleaned them but still getting the errors. Think I might just have to order a cluster and see if these resolves the problem. really frustrating
Post #617323 Thu Sep 16 2021 9:08am
80% cluster.
If it shutting down it needs a fix anyway
Dash contains the imboliser code. So you can just fit a replacement without programming.
If getting a use one,
Milage must be Lower than the car. You can only increase. No decrease
Post #617329 Thu Sep 16 2021 11:39am
gazmlrs
Thanks - I got a replacement cluster - (mileage was less incidentally) - had a garage move the data from the old cluster to the new and tried to reprogram using landrover sdd website… it failed when trying to install the software saying it couldn’t communication with the transfer/power train control unit - error A01
he tried for the best of 3 hours and still nothing. He then reverted back to the old cluster and had the same issue - car wouldn’t start… this led our investigations to the TCU behind the battery. We took the tcu off and found some oxidisation in the unit and connectors - we replaced the unit and cleaned the connectors and the car started….. but still getting the oil, seatbelt, low washer faults together - plus I’ve notice it’s more Prevalent with the headlights on (I think in auto lights switch but I am monitoring)
So weird!
I have so far
Replaced the battery
Cleaned all internal ground points on passenger and driver kick plates
Cleaned visible earth points within the engine bay
Replaced the oil sender unit
Bought a used cluster in the hope to reprogram
Changed the TCU
Cleaned the connections to the tcu
Next port of call is to check the earth / ground points behind/above each front wheel on the chassis / wings
Then sending eh cluster off for repair to se if that solves the problem
If anyone else has any ideas - I’d be will to go down that rabbit hole 🤣 -
I am 2 weeks in to my RRS owner experience and I’m loving it - albeit frustrating at times
Post #617410 Fri Sep 17 2021 8:15pm
gazmlrs
Andy K wrote:
80% cluster.
Hi Andy,
I got a 2nd hand cluster same part / model etc! Fitted it the car and it had a hissy fit! Wouldn’t start, so put my old one back in and car won’t start now! Everything seems to work door locks, steering column - but the key just clicks and no crank, immobiliser light still flashing single while key in —- Any ideas?? It’s like the car is immobilised….
Post #617748 Mon Sep 27 2021 10:20pm
Ur I think the clue was here Rolling Eyes
The code is the dash doesn't match the other 2 codes
As to how you fix it now, I don't know.
Wait a few hours?
If that fails, disconnect battery
Post #617760 Tue Sep 28 2021 7:24pm
