Home > General > Power steering leak
Simonhunt72
United Kingdom 2006 Range Rover Sport Supercharged Bonatti Grey
Power steering leak
Hello all, a new issue arose today ,noticed noise on power steering, checked fluid level and was really low.topped up to find fluid on floor . So had a look and found fluid dripping from near side gator, removed clip and poured out!! Is this a serviceable part or new rack ,any advice /guidance welcome tia
Post #607929 Mon Dec 28 2020 5:26pm
There are 2 different types of rack if you do find spare parts or require a replacement
Helps to fill in your profile
Post #607934 Mon Dec 28 2020 7:16pm
Simonhunt72
Hi Andy ,thought I did when I joined!!! Will sort that out, 2006 4.2 supercharger
Post #607936 Mon Dec 28 2020 7:45pm
Simonhunt72
And all filled out ,thanks for the prompt! Have had a search, not bringing much joy!!!
Post #607945 Mon Dec 28 2020 8:43pm
Try here
https://www.advancedfactors.co.uk/
Post #607946 Mon Dec 28 2020 8:54pm
Simonhunt72
Andy K, thank you 👍
Post #607950 Mon Dec 28 2020 9:04pm
All L/R rack part numbers now appear to supersede to one number LR031745 and L/R's price is in excess of 2K but looks like the part may even be obsolete from L/R, they do not list a repair kit for them either. You may be able to use that part number to find a aftermarket one as I believe they may be either a ZF or Bosch rack, worth having a look at old rack to see if you can find L/R's engineering number label on it which may make it easier to find one (Should look similar to photo shown below) the 10 digit number to the right is the manufacturers number. You may also need new track rod ends as well if the rack doesn't come complete with them, as they did change the rod/spindle thread from 12mm to 14mm on later racks.
Post #607957 Tue Dec 29 2020 7:36am
knwatkins
Give Lion Automotive a call
https://www.lionautomotive.co.uk/category/land-rover/sport
A recon rack will be about £225 plus £100 surcharge. They will collect your old rack when you have fitted the new one and refund you the £100 surcharge upon receipt. 3 year warranty.
One of the guys on the Disco forum used them last year and his review was very positive...
https://www.disco3.co.uk/forum/steering-ra...81336.html
Hope this helps Thumbs Up Kev
Post #607963 Tue Dec 29 2020 11:34am
Simonhunt72
Thank you guys ,hopefully sourced one!
Post #607991 Wed Dec 30 2020 2:22pm
