Home > General > Power steering leak |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
There are 2 different types of rack if you do find spare parts or require a replacement
Mon Dec 28 2020 7:16pm |
Simonhunt72 Member Since: 13 Jan 2019 Location: Somerset Posts: 68 |
Hi Andy ,thought I did when I joined!!! Will sort that out, 2006 4.2 supercharger |
Mon Dec 28 2020 7:45pm |
And all filled out ,thanks for the prompt! Have had a search, not bringing much joy!!! |
Mon Dec 28 2020 8:43pm |
Try here
Mon Dec 28 2020 8:54pm |
Andy K, thank you 👍 |
Mon Dec 28 2020 9:04pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
All L/R rack part numbers now appear to supersede to one number LR031745 and L/R's price is in excess of 2K but looks like the part may even be obsolete from L/R, they do not list a repair kit for them either. You may be able to use that part number to find a aftermarket one as I believe they may be either a ZF or Bosch rack, worth having a look at old rack to see if you can find L/R's engineering number label on it which may make it easier to find one (Should look similar to photo shown below) the 10 digit number to the right is the manufacturers number. You may also need new track rod ends as well if the rack doesn't come complete with them, as they did change the rod/spindle thread from 12mm to 14mm on later racks.
Tue Dec 29 2020 7:36am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Give Lion Automotive a call
Tue Dec 29 2020 11:34am |
Thank you guys ,hopefully sourced one! |
Wed Dec 30 2020 2:22pm |
