![]() | Home > Technical > Folding rear seats |
They (canvass loop) are at the back of the seat just in the middle. You have to be mindful to leave them proud when putting the seats back to the sitting position. 2006 2.7 TDV6 HSE in Cairns Blue. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
put your hand down the back, and try and locate them |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
I have to say that this foxed me the first time I tried to lay the seats flat There is no replacement for displacement - W O Bentley
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
To state the bleeding obvious, you need someone with small hands. The tab is not that long and will have “fallen” down.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9028 ![]() ![]() ![]() |
You can also reach under the rear seat from the boot by pulling the boot floor flap out of the way. This is the flap that folds down to bridge the gap between boot floor and seat back when the seats are flattened. That might give you a way in to find the loop. 2012 SDV6 - it's missing a couple of cylinders
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 952 ![]() ![]() ![]() |
One of the loops did snap on mine, but not the one on the seat Base, the one that releases the back of the seat from the folded flat position. But I'm also continually losing the loops that release the Base, once you've found them it's easy the second time 2010 RRS, TDV8
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Gogsy, believe it or not you can actualy buy new straps for the back of the rear as one broke on mine, but I just use a cable tie.
SomersetRRS Member Since: 18 Nov 2019 Location: Somerset Posts: 65 ![]() ![]() ![]() |
Thanks all, I'll take another seat. Been looking under the seat from the boot and from the side doors and nothing was obvious but I'll have another rummage and see what I can see. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
If in doubt - read the handbook |
Thanks for the hint, Garry. This has been driving me nuts - I'm pretty mechanically minded and after reading posts thought it would be dead easy to find the strap. Maybe I'm unlucky and mine have disappeared but I'll take another look. |
Col,, I assumed they weren't replaceable as the strap is wrapped around a bar and stitched,,,, unless they unhook somehow. I've got into the habit of pushing down on the release button rather than pulling on the strap. 2010 RRS, TDV8
Yeah, they just unhook and are about £3.00 each. HPH500180PVJ I press down on mine to release it now most of the time as well. Straps not the best idea they just wear through on the sharp edge of the metal bracket.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
The straps (loops) on mine are stitched on to the back of the seat cushion about half way along the nearside and offside seats between the seat cushion itself and the back of the seat.
I was actualy referring to the straps on the back rest being replaceable not the seat cushion. |
