Home > General (L494) > Silver centre console trim removal |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 133 |
Does anyone know how the get the silver side trims from the centre console removed? I have removed the dash panel and exposed the top of the silver trims, but having a go with a sharp pull, feels like I'm going to break something.
Sat Dec 05 2020 12:15pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
It’s not that bad but dash cover really needs to pop off the rear ac unit pops off, under the little rubber tray that just pulls up there are 2 bolts 8mm and it pull off top first then bottom there is a cable for the ac at the bottom so go easy.
Sat Jan 16 2021 12:49am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
yep, you have to start by removing the rear AC cover:
Sat Jan 16 2021 6:35am |
Thanks everyone Current - 2020 Range Rover Sport P400e
Sat Jan 16 2021 12:05pm |
