![]() | Home > General (L494) > Silver centre console trim removal |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 143 ![]() ![]() |
Does anyone know how the get the silver side trims from the centre console removed? I have removed the dash panel and exposed the top of the silver trims, but having a go with a sharp pull, feels like I'm going to break something.
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 411 ![]() ![]() |
It’s not that bad but dash cover really needs to pop off the rear ac unit pops off, under the little rubber tray that just pulls up there are 2 bolts 8mm and it pull off top first then bottom there is a cable for the ac at the bottom so go easy.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1195 ![]() ![]() ![]() |
yep, you have to start by removing the rear AC cover:
Thanks everyone Current - 2020 Range Rover Sport P400e
