![]() | Home > Technical > Red Suspension Light |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Check the arc fluid under the bonnet.
Tilz Member Since: 23 Jul 2020 Location: Harrow Posts: 9 ![]() ![]() ![]() |
Thanks - that’s full, no loss of fluid. |
the_wombat Member Since: 29 Oct 2020 Location: Huntingdon Posts: 64 ![]() ![]() ![]() |
Would be good to try and get the fault code to help with an accurate diagnosis.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9028 ![]() ![]() ![]() |
Could be the signs of a compressor exhaust valve starting to fail. These can be random failures until they become a permanent one. 2012 SDV6 - it's missing a couple of cylinders
