Home > Technical > Red Suspension Light
Tilz
Crying or Very sad
Hi all. Car is 2005 RR Sport 4.2 SC. Was driving along two days ago and went over a pothole i think. Red suspension light came on shortly after and asked to safely stop. Light went from flashing red to solid red. Anyway, carried on the journey, got home and turned car on and off; light went away. Lifted car to off road and lowered to access - no issues at all.
Today went for a test drive, no issues. About 20 minutes in, red light appeared again randomly. Again carried on and came on home. Turned car off and on, light is gone.
What could be the issue? I only have an OBD scanner and no fault codes reported. If you think I should get a IID scanner; is there a really cheap version you would recommend? Either way, I’ve read things from battery, brake light switches, compressor, height sensors etc could be the issues. Dont know where to start!
Thanks in advance all.
Post #606216 Tue Nov 03 2020 8:38pm
Check the arc fluid under the bonnet.
Drivers side
Post #606219 Tue Nov 03 2020 9:39pm
Tilz
Thanks - that’s full, no loss of fluid.
Post #606222 Tue Nov 03 2020 10:36pm
the_wombat
Would be good to try and get the fault code to help with an accurate diagnosis.
If you’re close to Huntingdon, I could help out.
Post #606227 Tue Nov 03 2020 11:29pm
Could be the signs of a compressor exhaust valve starting to fail. These can be random failures until they become a permanent one. 2012 SDV6 - it's missing a couple of cylinders
Post #606228 Tue Nov 03 2020 11:32pm
