Home > Maintenance & Modifications > Fluid drips at the rear
Gjlatz
Scotland 2012 Range Rover Sport SDV6 HSE Lux Siberian Silver
Hello everyone, haven’t posted for a while but looking for your opinions. Noticed some drips on my garage floor and my first thoughts were front pinion diff seal. After a look underneath the diff is dry but just above the front of the rear diff is where the leak appears to be. I’m assuming that this is ACE fluid? I haven’t checked the ACE fluid level in the reservoir yet. The attached photos show the fluid above the prop/rear diff.
Just checked the ACE fluid reservoir level and it’s still full as is the brake fluid level?
Many thanks
Garry
Post #606143 Sun Nov 01 2020 5:12pm
Brit Plumber
You won’t notice any level change with a few drips. It’s likely just started leaking as you would have noticed earlier. I can’t see your photos but I would suspect your ARB or the pipes. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #606145 Sun Nov 01 2020 8:18pm
Rear ARB. Budget £1500 to replace unless you're lucky and it's just the pipe union. 2012 SDV6 - it's missing a couple of cylinders
Post #606146 Sun Nov 01 2020 8:36pm
Gjlatz
Thanks for the reply. Just edited the post and added the photos. I was initially glad it wasn’t the diff but I think the diff would be an easier fix.
Garry
Post #606147 Sun Nov 01 2020 8:38pm
Gjlatz
Hi RRSTDV8, thanks for the estimate. Do you know if the unions are accessible without lifting the body?
Post #606148 Sun Nov 01 2020 9:06pm
Disco_Mikey
Rear body needs lifted to replace the rear pipes and/or bar...
Post #606150 Sun Nov 01 2020 10:46pm
Gjlatz
Hi Mike, thanks for confirming.
Post #606154 Sun Nov 01 2020 11:15pm
p38
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Firenze Red
Hi ive just had both of mine , rear and front, replaced and pipes replaced at wait for it £3500 i know its a lot of money but they had to be done.
Post #607842 Thu Dec 24 2020 4:06pm
Gjlatz
Hi P38, thank you for the information. I have had a fixed price that is quite a lot less but I don’t know if we would be comparing like for like.
Garry
Post #607849 Thu Dec 24 2020 6:13pm
