![]() | Home > Maintenance & Modifications > Fluid drips at the rear |
You won’t notice any level change with a few drips. It’s likely just started leaking as you would have noticed earlier. I can’t see your photos but I would suspect your ARB or the pipes. 2019 5.0 SC SVA (Current)
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Rear ARB. Budget £1500 to replace unless you're lucky and it's just the pipe union. 2012 SDV6 - it's missing a couple of cylinders
Gjlatz Member Since: 01 Mar 2019 Location: UK Posts: 40 ![]() ![]() ![]() |
Thanks for the reply. Just edited the post and added the photos. I was initially glad it wasn’t the diff but I think the diff would be an easier fix.
Hi RRSTDV8, thanks for the estimate. Do you know if the unions are accessible without lifting the body? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Rear body needs lifted to replace the rear pipes and/or bar... |
Hi Mike, thanks for confirming. |
p38 Member Since: 04 Jul 2019 Location: flintshire Posts: 51 ![]() ![]() ![]() |
Hi ive just had both of mine , rear and front, replaced and pipes replaced at wait for it £3500 i know its a lot of money but they had to be done. |
Hi P38, thank you for the information. I have had a fixed price that is quite a lot less but I don’t know if we would be comparing like for like.
