Home > Technical > Battery Options
Autobiography1969
Battery Options
Hello all,
Had a service recently and was informed it may be time to consider changing
the battery, so asked the MOT garage if they could check the condition with
winter coming, they said the battery was in good condition but could do with
a run to just bump it up a little,
It normally sits on an app I have around 11.9-12.2 with little change and I am
not 100% sure how accurate the app is,
With this in mind I phoned the local dealer as I was informed by the RAC that my
2012 would need to be programmed once the new battery was installed,
The dealer wants £412 to do it all including the programming,
What is this programming and does it have to be done or can I get a better battery
else where and not have it programmed??
TIA,
Neal ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #606097 Fri Oct 30 2020 8:17pm
That is crap, it is advised to reset BMS after fitting new battery, but they will recalibrate themselves over time buy I'm sure a Indi will do it cheap enough though, I replaced mine 4 years ago and never reset anything and never had a issue, buy a battery from the likes of Tanya and fit it yourself, just make sure the battery is fully charged before fitting.
Post #606101 Fri Oct 30 2020 8:49pm
Autobiography1969
Thank you,
can the BMS be reset using the IID Tool?
I have one but I only really use it for the code reading.. ===========================================
Post #606103 Fri Oct 30 2020 9:00pm
Yes, no problem there are a few options in there to change battery capacity if you fit a different rated one, but not sure if it really makes a difference. Thumbs Up
Post #606104 Fri Oct 30 2020 9:10pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
As Col says the battery monitoring system will, over a short time, work out what type of battery has been fitted ie an AGM or non AGM.
If you replace an AGM with another AGM then you don’t need to do anything and your quote is an attempt at a rip-off.
Post #606110 Fri Oct 30 2020 10:54pm
I actually replaced the original factory Wet battery for a larger capacity 95Ah 850A AGM on my S/C, as they only ever fitted 700A Wet to the petrol RRS1's for some reason and as said never changed anything and never had a problem.
Post #606112 Fri Oct 30 2020 11:20pm
Brit Plumber
Don’t buy a YUASA 019, I’ve Been through 3 in 18 months under warranty and now have an AGM. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #606114 Sat Oct 31 2020 12:39am
Re: Battery Options
Autobiography1969 wrote:
Hello all,
Why are you using a dealer on an 8 year old vehicle? You may as well just walk in with your trousers around your knees and bend over in front of the service desk.
Get thee to an indie, save a load of money and get better treatment.
£400 to replace a battery. Really? FFS. Rolling Eyes 2012 SDV6 - it's missing a couple of cylinders
Post #606115 Sat Oct 31 2020 12:55am
Stevepd
I’ll change your battery for £400 Mr. Green 2006 2.7 TDV6 HSE in Cairns Blue.
Post #606117 Sat Oct 31 2020 7:46am
Pufftmw
Re: Battery Options
Hello all,
To be fair to Neal, he may not be too mechanically minded. Its (unfortunately) because of customers like this that the RAC etc can charge such outrageous fees for simple stuff. Thing is, we know that a battery change is not hard and that's why we visit forums like this to pass on knowledge.
Post #606121 Sat Oct 31 2020 11:40am
Autobiography1969
Forgot to come back on this,
The reason for the quote is I just wondered how much they would charge,
as on the odd occasion they come in reasonable but as you say most of the time they
are trying to take the micky,
I am still looking as the current battery is still working well,
I do have an question though
Can you have too high rated battery,
I have found the one that is the right size 019
Ampere Hours - 100
CCA (SAE) - 1100
Technology - AGM
Weight - 27 kg
Would this be OK or too much?
Also can you use a stop start battery on a none stop start car? ===========================================
Post #611371 Thu Mar 11 2021 10:41pm
No problem using a Stop/Start AGM battery, had a Varta one on mine for nearly 5 years with no problem.
Post #611405 Fri Mar 12 2021 9:11pm
Autobiography1969
Thank you Col.. ===========================================
Post #611412 Fri Mar 12 2021 11:28pm
riverblanche
Hi,
Had an AGM battery on our TD5 disco about 15 years ago Thumbs Up
If a battery is labeled as a S/S it is because it can handle the loads the S/S system puts on it
You could consider it an upgrade if you don't have S/S Whistle
You can now get EFB as well, (thread over on RRS) which is Enhanced Flooded Battery
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #611421 Sat Mar 13 2021 11:26am
Autobiography1969
Thumbs Up ===========================================
Post #611427 Sat Mar 13 2021 4:24pm
